Making pockets
Making pockets
georgeENF84
Making pockets
georgeENF84
Hello: I drew my odd shaped part I press pulled it to its thickness I put in all the assorted holes press pulled them so they look like holes through the part now I am trying to put in the pockets for the various components that fit inside the part, some of the pockets overlap the outside edge of the part I think this is where I am getting in trouble. I have used Gibbscam quite a bit and some times you have to disconnect the lines to make different operations work, one of the pockets I made I can see that it moved the line the correct distance into the part but it did not give me the 3d look because I think the original outside line was still there ..... anyway... help me obywonknobe your my only hope 🙂
davebYYPCU
Difficult to help, without the file, screencast or screenpics
TheCADWhisperer
georgeENF84
Hi .... Attached you will find my pocket problem ..... you have a picture of a rectangle which is .500 thick ..... in the upper left hand corner you see another square I want that down into the material  .130 .... thank you for your help 🙂
jeff_strater
Hi @georgeENF84,
Is what you want to just use that sketch rectangle to cut into the block?
Here is a screencast showing how to do that, either to the bottom (where the sketch is), or the top of the block
Jeff
Jeff Strater
Engineering Director
georgeENF84
That was the answer .... Thank you very much 🙂
