Making multiple different polygons the same height
Message 1 of 16
I am attempting to make 4 different solids of constant width, a triangle, a pentagon, a heptagon, and a nonagon. These all need to be the same height in order ro roll togther. Unfortunely, none of the polygon tools allow for creation using one side and one corner, so they come out different heights. Is there any way around this?
Replies (15)
Message 2 of 16
rohit.bapat
Hello @Anonymous
Could you please post an image or some representation of what you are trying to achieve?
Thank you,
Rohit Bapat
Rohit Bapat
Product Owner
Message 3 of 16
etfrench
Create one of the polygons with the desired height. Create the others with any height (Use the same orientation for all of the polygons).  Use the Scale command to make each polygon match the first.  Hint: You can enter a formula in the Scale Factor entry field.
p.s. You'll have to decide if you want the width or the height equal. I don't think you can have both.
ETFrench
Message 4 of 16
TrippyLighting
Is this what you are looking for ?
Message 5 of 16
etfrench
I stand corrected Smiley Happy
ETFrench
Message 6 of 16
Yes! Certainly! How do I do that?
Message 7 of 16
etfrench
Look closely at @TrippyLighting's post.  He shows how to make different polygons using dimensions instead of using the Polygon tool.  This has the advantage of being (more) parametric than the polygon tool.
The following polygons were created with the Polygon tool using the Inscribed Polygon option.  The circles were created first using a rectangular pattern.
ETFrench
Message 8 of 16
Actually, on closer examination of both the posts, it seems that the height seems to increase slightly with the number of sides. Is there a way to make it so that the distance from the middle of the bottom face to the apex of the shape is the same across different polygons?
Message 9 of 16
TrippyLighting
Yes, of course. If you look at my screenshot agin it'll be self evident how o do that ?
Message 10 of 16
Ohhhhhh I get it.
Thank you all a heap for putting up with me not getting that.
Message 11 of 16
TheCADWhisperer
It is not evident to me.
Can you File>Export and then Attach your *.f3d file here?
Message 12 of 16
TrippyLighting
Instead of dimensioning it horizontally, you dimension it vertically .. with the equally evident consequences.
In other words it might still not do what the OP wants to do, but then the student has learned from experimenting  and IME  that knowledge usually sticks better than from being given a straight answer.
Message 13 of 16
TheCADWhisperer
If a picture is worth a thousand words> the geometry might be worth a thousand pictures.
I understand geometry better than the word problem descriptions.
Can you File>Export  and then Attach your *.f3d file here?  (The response is a binary Yes or No).
Message 14 of 16
It is indeed what I wanted.
These 3 solids of constant width will now roll smoothly supporting a flat plane.
Message 15 of 16
TheCADWhisperer
@Anonymous wrote:
It is indeed what I wanted...
I do not see equivalent solutions (not considering the 60 vs 40 size)?
Message 16 of 16
In both cases, the "Sketch Dimension" tool is used. In Trippy Lighting's case, the width of each different shape is the same. In mine, the height of each different shape is the same.
(Pay attention to what way the black arrows are pointing.)
