feature request 2018
yoeproth
yoeproth
Here's a list of feature requests:
Model:
- ability to extrude multiple bodies/components from 1 sketch. Example: Sketch 1 contains 5 rectangles next to each other. Feature: Extrude: select all 5 rectangles, 'select new feature: seperate bodies'. Result: 5 boxes, next to each other, each box is seperate. Can be textured in Render seperately.
-when editing an existing fillet feature, ability to add fillets.
- within a sketch: sketch offset from another sketch offset.
- within a new sketch: offset lines from an older sketch.
- ability to name sketches and features
- highlight position of sketch or feature in the tree, when hovering over the model.
- quick feature: select a square, print. (paper)
Drawing:
- ability to copy - paste text boxes
- copy - paste selected drawing view
- copy - paste selected drawing view/textboxes between sheets
- basic auto dimension feature
- advanced/fully defined auto dimension feature
- ability to set auto dimension feature ON a.s. standard in sheet template
- feature to delete all dis-asociated measurements on current sheet with a shortcut
- create custom title-block feature. Basic lay-out options are enough.
- create custom title block as a sketch.
- ability to import .AI (logo) into title block
- button: send directly by mail.
Sent options:
PDF
DWG
PDF and DWG.
- drag dimensions with 1 click. Ability to grab anywhere on textbox.
- ability to create a drawing from a model which contains of sketches only (and doesn't have bodies/components/extrude features)
- ability to have full control of the isometric view angles. Thus being able to slightly turn the view angle.
- set isometric view(s) to perspective or non-perspective, just like in Model.
- arrow-textbox: being able to set the arrow anywhere, regardless of wether there is a line/point/etc.
- set standard font size. ability to save this setting within template/for all sheets.
- ability to include textboxes in template.
- ability to save a textbox template (and to import it into drawing)
- remember previous set font size (based on previous session)
- ability to copy/paste text, also between sheets
General:
- option: store all files offline, local HDD
- interactive tutorials within F360, including voice-over option
- look-at shortcut by pressing a keyboard-key and a plane
 Render:
- saved favorite textures are gone after latest update. Bug?
TrippyLighting
And you feel that with your limited experience you should be posting requests ?
1. -when editing an existing fillet feature, ability to add fillets.
 that can already be done. Just press the CMD or CTRL ket while selecting.
2.  within a new sketch: offset lines from an older sketch.
you'll have to project those entities for the old sketch into the new one. then you can offset them.
3. - ability to name sketches and features
Can already be done. Right click on feature in timeline and select "rename".
4. - highlight position of sketch or feature in the tree, when hovering over the model.
That would not work easily as one sketch can create several features., see your own request.
TheCADWhisperer
You are in luck - to quote Autodesk,
"You’ve got brilliant ideas – and we want to hear them! At ideaStation, we’re talking future product features and discussing the next new thing."
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125
yoeproth
thanks both for the reply
