feature request 2018
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here's a list of feature requests:
Model:
- ability to extrude multiple bodies/components from 1 sketch. Example: Sketch 1 contains 5 rectangles next to each other. Feature: Extrude: select all 5 rectangles, 'select new feature: seperate bodies'. Result: 5 boxes, next to each other, each box is seperate. Can be textured in Render seperately.
-when editing an existing fillet feature, ability to add fillets.
- within a sketch: sketch offset from another sketch offset.
- within a new sketch: offset lines from an older sketch.
- ability to name sketches and features
- highlight position of sketch or feature in the tree, when hovering over the model.
- quick feature: select a square, print. (paper)
Drawing:
- ability to copy - paste text boxes
- copy - paste selected drawing view
- copy - paste selected drawing view/textboxes between sheets
- basic auto dimension feature
- advanced/fully defined auto dimension feature
- ability to set auto dimension feature ON a.s. standard in sheet template
- feature to delete all dis-asociated measurements on current sheet with a shortcut
- create custom title-block feature. Basic lay-out options are enough.
- create custom title block as a sketch.
- ability to import .AI (logo) into title block
- button: send directly by mail.
Sent options:
DWG
PDF and DWG.
- drag dimensions with 1 click. Ability to grab anywhere on textbox.
- ability to create a drawing from a model which contains of sketches only (and doesn't have bodies/components/extrude features)
- ability to have full control of the isometric view angles. Thus being able to slightly turn the view angle.
- set isometric view(s) to perspective or non-perspective, just like in Model.
- arrow-textbox: being able to set the arrow anywhere, regardless of wether there is a line/point/etc.
- set standard font size. ability to save this setting within template/for all sheets.
- ability to include textboxes in template.
- ability to save a textbox template (and to import it into drawing)
- remember previous set font size (based on previous session)
- ability to copy/paste text, also between sheets
General:
- option: store all files offline, local HDD
- interactive tutorials within F360, including voice-over option
- look-at shortcut by pressing a keyboard-key and a plane
Render:
- saved favorite textures are gone after latest update. Bug?
