Making gun grip checkering
Message 1 of 16
Hello.
I making gun grip for toy now.
I want make SIG P220 grip like.
But, I am stuck in making grip checkering to solid body.
I don’t know what to do.
Help me.
Replies (15)
Message 2 of 16
lichtzeichenanlage
Perhaps those videos might help you:
BTW: Knurling might the keyword for your (re-)search.
Message 3 of 16
Thanks!
It was very helpful.
But...it will only work on CAM workspace?
I want make same knurling on Model workspace.
Message 4 of 16
lichtzeichenanlage
@tasukuwat: You can do it in the model environment, but things might get slow very quickly because the number of faces that have to be recalculated do increase a lot. That's how I would do it (I haven't prepared anything for the cast so what ever you see might be a bit clunky):
And here is the design so you can play around with it:
Message 5 of 16
@lichtzeichenanlage
Ummm...It's seems to knurling in CAM is better than model workspace.
I'll try CAM mode.
Thanks a lot.
Message 6 of 16
lichtzeichenanlage
Ill guess this is a good decision.
Message 7 of 16
davebYYPCU
Are you sure you want to go that way, saving as STL, Yuk.  Not for me.
Only saving grace is the flat sided outcome.
Two straight sweeps, and a third for the bounding line, bit or work, but better than STL.
My 2 cents....
Message 8 of 16
lichtzeichenanlage
@davebYYPCU: Valid 2 cents. I'm 3d printing things. And this would be a kind of post processing step and would be fine for me. But it wouldn't be visible in e.g. renderings. What's so bad about stls?
Message 9 of 16
davebYYPCU
Manipulation of mesh bodies in Fusion is less than brilliant,  fine in Meshmixer.
I am also thinking, taking the model to Cam, Lars did not mention saving out the model after cutting, only the stock after / in simulation, could be a long way round to the end result.
I did say that the flat faces in knurling would be one reason to put up with it.
I also concede, the end result going to a printer has to be stl.
Message 10 of 16
davebYYPCU
The loss of edges, and crisp definitions, same body exported with Fusion settings (high definition is my default), and inserted.
I didn't know, until now, but you cant add appearances to mesh models, I had intended to colour them the same with a wood grain.
Message 11 of 16
This file is what I was talking about.
If someone comes up with a cool idea please use this.
In short,
CAM knurling is easy way,but Only on STL.
If I import these STL files to other design, may I lose edges on grip.
Did I say it right?
Message 12 of 16
My uploaded file has some trouble.
This is repaired file.
It may work.
Message 13 of 16
davebYYPCU
I have this version done,
Normal to have grips screwed onto chassis.
Message 14 of 16
dade002001
Community Visitor
Community Visitor
Hello, is it possible for me to get a 220 grip design? I really need it, please
Message 15 of 16
dade002001
Community Visitor
Community Visitor
please Contact me on WhatsApp +9647714888723
email dade002001@gmail.com
Message 16 of 16
davebYYPCU
It was a mock up, don't know if size and or fit will be of use.
Might help....
