- Mute
- Permalink
- Report
Hi, I've mocked up a 5 sided box, with a front I'm trying to make a track for a cover, and then the negative of the track to fit within the space I'm cutting out with the extrude option.
I first tried to do a isosceles trapezoid prism, but my skillset is very lacking and I couldn't get it to be quite right, so instead I used a rectangular prism.
I was able to extrude out the shape, and also copy out the shape and rotate it 90 degrees to become the cover, but the print came out and I had negative tolerance. I can sand this down, but I know there's a better way, I just can't seem to wrap my head around it.
I've attached the 4 sided box, which is the precursor to what I did with the 5 sided box. I've also attached the 5 sided box, that the cover doesn't slide into the groove because the tolerances are uh.. 0.
My ideal mockup would have been the isosceles trapezoid with the angles of the triangles cutting out to the 2/3 point of the print (1mm, since it's 3mm thickness.) 2mm back from the front so I can slot the blinds into the holder, and then put the cover in front so I can finally use my blinds like they should be able to be used. (Bought the house, the previous owner only replaced the blinds, but not the blinds holders. So every single blind in my house is just sitting there, but falls out if you try to use them without holding them in place. Super fun.)
I watched a couple of videos and tried to apply what they talked about to what I'm trying to do, but I guess I'm not tying it together right to work quite like I imaged, so what am I doing wrong, or am I mostly on the right track?
(V3 is actually the 4 sided box, v2 is 4 sides plus cover.)
