Making a solid out of my imported STL mesh
Hi there, im very new to Fusion 360 and currently trying to make a solid out of my imported STL surfboard, so i can edit it for 4 other models. Eventually i am sending them to be made with a 5 axis CNC machine for use in a towing tank. I will also be using them for CFD analysis too.
Basically i tried to make a closed mesh, but it went all weird, so i tried pulling a t spline plane to the mesh but i can only do the underside, and its not quite the right shape anyway. any help would be amazing!
TheCADWhisperer
@Anonymous wrote:
...any help would be amazing!
Attach your original stl file here, but I must warn you (if it isn't visually obvious), stl is generally rubbish.
I think you would be better off -quality wise- to start over from scratch and design  your own geometry rather than trying to clean up someone else's rubbish.
wmhazzard
I agree with @TheCADWhisperer , draw it yourself and you will have better results. If you still want to convert the mesh, there are hundreds of videos on Youtube on converting meshes to solid.
thoreaubakker
You could try turning it into a quad mesh using this free software: (Instant Meshes)
https://www.youtube.com/watch?v=9sV88Z3cXdY
Then re-import it and then convert to a t-spline body, then to a solid..
Thanks everyone, i managed to do it by converting it to a part and then patching and stitching the holes to the main body. Thankyou very much for your fast replies though!
thoreaubakker
Good job!
Happy it worked for you  🙂
Thankyou, out of interest, how would i draw it myself?
