- Mute
- Permalink
- Report
My goal was to create an independent, mirrored copy of a component that would be a new component and move independently from the original.
After trying numerous ways to do this, the only way I found that actually worked was to first (collectively) copy all the bodies in the original component and paste them into a new, empty component. Then, I mirrored them (collectively) about the appropriate plane and, finally, "removed" the unmirrored copies (deleting them wiped out everything of course).
Now this seemed to be a really clunky way to go about doing this (and I have a bunch more to do) so my question is: how can I do this in a more direct and efficient way?
In fact, this whole business of copying and pasting is much more complicated and mysterious, it seems, than I would have expected. The "mirror" command just creates new bodies within the original component that are connected "motion-wise" to the original but seem to be unconnected "edit-wise". That is to say, editing the original didn't change the mirrored bodies. If I copied the whole component, as opposed to just its bodies, it offered the choice of "paste new" (which seemed promising) but put the new component as a sub-component inside the original component and I couldn't pull it out and move it up to the same level as all the other components.
Anyway, sorry to carry on about all this. What I would really appreciate is a thorough, in-depth explanation of copying and pasting or some links to the same. Thanks in advance. I've attached a copy of the file. The component I copied and mirrored was the "Wing Root Left" to make the "Wing Root Right".
