I've been trying to get through the basic tutorials off and on for several months. I proceed until the instructions stop working then give up.
Today, I'm trying to build the base and neck section of the lamp. Step 13 says to select the side profile of the neck body and Press O to enable the Offset command. I do so.
The next step says to click on the edge of the profile and move the cursor inward. This will create a perimeter offset represented in red. Enter a value of 30 mm and press enter to finish. I cannot click on the edge - it does not highlight. The only way I can get this to work is to right click on the side again, drag down for the sketch menu, then choose offset from there. After doing this, the edge is finally selectable. Dragging inward yields a value of -30mm, not 30mm (negative, not positive)...
Step 15 says that I should now select the longest edge of the offset sketch and drag it outside the body. Click STOP SKETCH to finish. This does not work no matter what I try.
Back to 3ds max, I guess 😕
