Tutorial bugs are discouraging...
Message 1 of 15
I've been trying to get through the basic tutorials off and on for several months.  I proceed until the instructions stop working then give up.
Today, I'm trying to build the base and neck section of the lamp.  Step 13 says to select the side profile of the neck body and Press O to enable the Offset command.  I do so.
The next step says to click on the edge of the profile and move the cursor inward. This will create a perimeter offset represented in red. Enter a value of 30 mm and press enter to finish.  I cannot click on the edge - it does not highlight.  The only way I can get this to work is to right click on the side again, drag down for the sketch menu, then choose offset from there.  After doing this, the edge is finally selectable.  Dragging inward yields a value of -30mm, not 30mm (negative, not positive)...
Step 15 says that I should now select the longest edge of the offset sketch and drag it outside the body. Click STOP SKETCH to finish.  This does not work no matter what I try.
Back to 3ds max, I guess 😕
Replies (14)
Message 2 of 15
joel.palioca
If your able to share a video or file with what you are doing I may be able to offer some advice.  We have some plans in place for the future to offer some better improvements to our in product tutorials but they are still being worked on.  In the mean time I am more than happy to help get you through some of the areas your getting stuck.
You can share a file by sharing a public link from the data panel, or exporting out the file as an .f3d.  If your able to add the video that would help as well so that I can follow your current steps so that I understand exactly what you are doing.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
Message 3 of 15
keqingsong
@Anonymous thanks for bringing these to our attention. We made some significant changes and improvements to our Offset tool by making it associative with the original profile it is offseting against. With these changes, there are some behavior around Offset that also changed, like the how pressing O doesn't immediately allow you to select the profile contour. We've also introduced a manipulator to let you better control the offset size.
In order to move that longer edge freely, you'll have to delete a couple constraint to make that work. Please refer to the gif below.
We will update the tutorial to reflect these changes.
Cheers,
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 4 of 15
The GIF is broken. I cannot see it.
Message 5 of 15
TrippyLighting
Tutorials are great but I would rely too much on them Fusion is developing rapidly and how some tools work can change within a matter af a few weeks.
Jut pick smoeting you'd like to design, perhaps a prior 3DSMax project and see how that can be designed with Fusion 360.
Coming from a Subdivision Surface modeler such as 3DSMax the tools in the Sculpt workspace should be someahwt familiar to you.
Message 6 of 15
I got the gif to work finally.  Filtering.
It is not clear how you are deleting those constraints.  I see the mouse clicking on the offset icons, but nothing else.  No menus or changes anywhere else.
This program is not intuitive at all.  Just trying to get up to speed is a huge challenge...
Message 7 of 15
PhilProcarioJr
This is a prime example of why I wish the fusion team would not focus on videos as opposed to real documentation. The app is rapidly developing and the tools are constantly changing which makes videos obsolete very fast and frustrates new users to no end. I can't even count the amount of posts about steps from videos that no longer work and people wanting to give up on the software. This is not the way to win people over. It's a lot easier to update documentation as opposed to making all new videos.... And if you are going to have core videos that show how to use the app and an update changes the way the tools work then make it a point to update the video to coincide with the release....Once again in a week or so the solution for this will get lost on the forums and the community will be back to square one.....
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 8 of 15
keqingsong
@Anonymous to delete constraints, select the ones you want to delete and hit your delete key (or backspace).
@PhilProcarioJr We hear you both that we need to improve our we of keeping our documentation up-to-date. At the same time, we also need to be able to cater to a variety of learning styles, whether they are face-to-face, webinars, videos, and pics/text docs. As you have noted, the nature of Fusion 360 and it's rate of development has made this somewhat challenging on our side. We are working on a couple of projects aimed to provide better self help content, making it easier for you to find what you need, and get the support you deserve in a timely manner.
Keqing Song
Message 9 of 15
What is a constraint, and how do I select one???
Message 10 of 15
PhilProcarioJr
They are found in the sketch pallet and basical they are a way to define a relationship between entities in a sketch. More info can be found here:
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-A52508BD-DD3F-49E9-8A9C-9CDDA4581E10
Phil Procario Jr.
Message 11 of 15
keqingsong
@Anonymous A constraint is a rule that defines relationship of your sketch geometry such perpendicular, parrallel, coincident, concentric, etc.. They are the little white icons that appears when you create sketches. You can select them by clicking on them and delete them by clicking on them and then pressing the delete key (or backspace).
Here are some better ways to get started, especially with sketch: http://www.autodesk.com/products/fusion-360/learn-training-tutorials?_ga=1.203534544.1335027223.1445...
Our learning site has a number of new videos geared towards getting you familiar with how to design in Fusion 360.
Also, if you haven't already, check out this video series on Fusion 360 for Beginners:
Keqing Song
Message 12 of 15
This is what I see:  http://screencast.com/t/GhRqgrR6G
How do I select the constraint that should be deleted, and how do I know which one to select to begin with?
I've watched the video and the next one.  Creating a box isn't much of a challenge.  I'm trying to create a 3D printed case for this, though 😕
It's challenging, because there are 2 boards that both need mounts, I need to include a lipo battery and I want to avoid screws.  I need to understand the advanced tools and I need them to work 🙂
Message 13 of 15
TrippyLighting
The tools you need my be advanced, but the applicaiton of these tools don't require any advanced skills. In fact, the skills needed are rather basic. And tools work rather well, actually.
Unfortuanately I cannot watch your screencast from work as some stuff is blocked for security reasons. Perhaps use Autodesks Screencast tools (free download). It integrates well with Fusion and uploads the completed videos automaticaly to your A360/Fusion360 account and then sends you an email when its ready for viewing.
Message 14 of 15
Perhaps.  I haven't seen evidence of that yet.
Since I can't seem to edit my original post, here's the screenshot:
Message 15 of 15
TrippyLighting
Ahhh...Yes 😉
You got lucky in a sense. The way the offset tool works was change and vastly improved IMHO in the last update on Saturday. It is now fully constrained an parametric. When you want to edit an offset you only need to edit the offset dimension.
To delete the offset you left click on the constraint symbol - I believe it highlight in faint blue - and hit the delete key or right-click and select delete. This will delete only the offset condition but will leave the offset objects in place. If you don;t want them you'l have to delete them manually.
As I find that somewhat annoying in most use cases I've placed an idea in the idea station weeks ago to provide the user with an option to also automatically delete these offset objects on deletion of the offset condition. That idea actually applied to the pattern and mirror tools at the time and I am a little dissapointed that the new offset tool exhibits the same flaw.
