- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm making a panel for a building exterior. Each floor can have differing fascia detail.
Newbie!
I keep getting hosed up trying to stack detail on a layer because I don't understand if I'm sketching the origin plan, having to offset to the level I want, or if I can select a face as the plane I want to sketch on.
This personal confusion has caused Fs360 to just lock up beeping at me several times. After restarting I just try another path but that plane question is driving me nuts.
To keep each floor fascia as a separate component, I make a 0.1" base, attempt to build everything on that ...thinking that then they can be combined into a selection set so I can swap out fascia's as desired.
