MAKING A FLAT OBJECT CURVED
Message 1 of 10
Hi All;
I have a problem in a certain file.
I have an object that I have created. It has been made from different bodies and has been joined together.
Its a flat looking object but I want to convert the object into a slightly curved object.
How can I do this?
I have attached a picture of the pc I made on fusion and the original pc I am trying to replicate.
Kindly help me with the same.
Thanks!
Ila
Replies (9)
Message 2 of 10
TheCADWhisperer
The easiest way would be to model in finished form.
Trim and Thicken spherical surfaces.
Message 3 of 10
Thanks so much. Would you please guide me as to how to do that.
Thanks so much!
Message 4 of 10
TheCADWhisperer
Message 5 of 10
Hey,
Thanks so much.
Message 6 of 10
TrippyLighting
There is no file attached 😉
Message 7 of 10
mufadal89
You can try this.
Take the outline of the profiles and make a sketch.
Project that sketch on to a curve surface , the curvature with which you want to have that part to be.
Then use the projected outlines to make your new part.
Message 8 of 10
Will try that out and let you know. Thanks so much!
Message 9 of 10
TrippyLighting
Most of what you need is already in your model.
Roll the timeline back in the attached model, move it forward one step at a time and see if you can make sense of it.
This is the rendered end result:
Message 10 of 10
Hey this seems to be working!
Thanks so much!
And also everyone for the help!
