Makesolid failed du to invalid input
Message 1 of 9
Hello everyone,
I'm new on Fusion 360 and very enthusiastic about the mesh possibilities but it doesn't fit as I'd like to: I'm trying to rebuild a .stl file (just out of curiosity) with the "make closed mesh" command but I only get the error: "Makesolid failed du to invalid input". Does somebody know why (I attach the file to this message)?
2de question: How can I fix the second problem (2de file) witch is a non-manifold mesh?
Thanks a lot!
Replies (8)
Message 2 of 9
masa.minohara
Hi @Anonymous,
Welcome to the Fusion 360 community! I just noticed that the mesh body is inside out (notice the color difference) so please try "reserve normal" command in the Mesh environment. I hope this helps!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 9
Hi everyone !
I got a problem with an object that I imported at STL format.
I try to reverse the normal in the aim of having a closed mesh, but I can't selct the mesh...any idea ?
Thanks a lot !
Message 4 of 9
michallach81
It's clearly a bug. Selection picks only those faces which are directed toward our view. Which results in picking what's behind.
@Anonymous for now, try to rotate the view and keep selecting, it looks that selection keeps adding new faces:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 5 of 9
michallach81
You can also pick whole mesh from browser.
Michał Lach
Designer
co-author
Message 6 of 9
TrippyLighting
If you enable "Select through" in the selection filter settings you can window select all faces of the bunny at once.
Message 7 of 9
michallach81
I did enable Select Through, so that's not the case. Please watch the screencast, when I drew window I get only faces turned toward me, which in this example, where the right side is facing inward, I'm picking the one behind.
Michał Lach
Designer
co-author
Message 8 of 9
TrippyLighting
I would not have posted if I had not successfully tried.
Message 9 of 9
michallach81
Then it must be hardware related because I had ST enabled and I couldn't select all faces.
Michał Lach
Designer
co-author
