Make a joint to a specific dimensional point on a component.
I am trying to join the socket in the picture to the outside of cylinder tube at an exact dimensional location.
What is the best way to do this?
I managed to get the two pin ends to connect my making a small hole in them to snap a joint to. But this was easy because when you creat a hole it picks the center. So this will not work on this occasion, unless its possible to tell fusion exactly where to create the hole on the cylinder.
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi pendlej,
I would suggest to create a sketch with a point on the outside of your cylinder tube.
You can apply dimensions to take control over your point.
After that use a joint to fit the pin and the cylinder.
I created a video here:
https://screencast.autodesk.com/Main/Details/da97d7e4-5643-4327-b3a6-45778f298fb7
I hope I understood correctly what you are looking for.
Dennis Ossadnik
Senior Technical Support Specialist
That's exactly what I needed to do many thanks.
I considered the perpendicular plane but still couldn't get the sketch tool to recognise it and draw on it. I managed to get round it by placing a square bar inside the cylinder at the centre, which it would then allow me to sketch a circle on at a specific location and then press pull it out to cut a hole through the cylinder, then I could snap the centre of the socket to the centre of the hole.
I will follow your steps from now on as your way was much faster and much more efficient.
Can't thank you enough.
Kind Regards,
James
