copy/paste individual faces from a T-Spline body
paysagine
paysagine
I can't copy/paste individual faces from a T-Spline body. (like this tuto : https://www.youtube.com/watch?v=ixpb0hIgKGw )
The surface create (i select the 4 front face) not match perfectly and the surface is different (you can see the result on picture).
Please can you help me to solve this problem.
Alexandre
innovatenate
Autodesk Support
Autodesk Support
I suspect that you may need to select more faces to copy and paste to maintain the same geometry. You could try subdividing (command in the Modify menu) the existing faces before copying and pasting the sculpt surface.
I hope that helps. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
paysagine
subdivise command work well
Thanks a lot.
