Scripts - deleteMe failing
hanskellner
Autodesk Autodesk
hanskellner
I'm trying to delete some bodies from my model but the call generates an error dialog with the message:
Failed : InternalValidationError : rawNeutronObject() == NULL
Here's the piece of code making the call:
for (var iBody = 0; iBody < rootComp.bRepBodies.count; ++iBody) {
  var body = rootComp.bRepBodies.item(iBody);
  if ( body.name.indexOf("_Hole_") === 0 ) {
    body.deleteMe();
    break;
It looks for any body that has a name that begins with "_Hole_" and then deletes that body.
Is this the correct method for deleting a body?
Thanks.
Hans Kellner
Senior Manager, Principal Engineer
ekinsb
Thank you for reporting this.  I can reproduce the problem and have filed a report.
Brian Ekins
Mod the Machine blog
