Make a hole aligned with a point in a different component
rpsalas
296Aufrufe
5Antworten
Nachricht 1 von 6
rpsalas
I have a sketch in one component A and a body in another component B. I want to create a hole in B aligned with a point in A.
But when I make B visible to create a hole, Fusion hides sketch A (behind B I think) so I can't see where to put the hole. Or it says I don't have a body into which to make the hole.
0 „Gefällt mir“-Angaben
297Aufrufe
5Antworten
Antworten (5)
Nachricht 2 von 6
g-andresen
1. What does the timeline look like?
2.
Please share the file.
File > export > save as f3d on local drive  > attach to post
günther
Nachricht 3 von 6
rpsalas
Component called posts is supposed to lay out three points in a triangle which then would be used to create holes in the two bodies first and second floor.
I similarly want to lay out a grid of holes that would be made into each of the two bodies. I thought of using a similar technique.
Nachricht 4 von 6
g-andresen
no problem
günther
Nachricht 5 von 6
rpsalas
I was hoping to use the "hole" command with the sketch. Here's a video:
https://share.zight.com/7KuwZAj2
Nachricht 6 von 6
g-andresen
is also possible
günther
