I'm trying to make a jig that would hold a product housing while production employee screw a PCB inside the plastic.
The issue I'm having is that the product has a few part, some of them have gaps other part are really thin.
I've tried many things, but none of them seems to work as I need it.
Here's the product I want to make a jig so it's easier for production employee to screw the electric PCB insinde
Side section view of the product so you can see that there's some gap between parts
I tried to create a block a little larger than the product and than use "Combine/Cut" but the result is not what I want.
I tried to make a sketch and extrude it underneath the product, but I think that because of the gaps and hole fusion does not want to compute the extrusion. I tried to fill the void inside using "boundary infill" but it does not work the way I want.
