Design a holding jig from a stp file
testjig
testjig
I'm trying to make a jig that would hold a product housing while production employee screw a PCB inside the plastic.
The issue I'm having is that the product has a few part, some of them have gaps other part are really thin.
I've tried many things, but none of them seems to work as I need it.
Here's the product I want to make a jig so it's easier for production employee to screw the electric PCB insinde
Side section view of the product so you can see that there's some gap between parts
I tried to create a block a little larger than the product and than use "Combine/Cut" but the result is not what I want.
I tried to make a sketch and extrude it underneath the product, but I think that because of the gaps and hole fusion does not want to compute the extrusion.  I tried to fill the void inside using "boundary infill" but it does not work the way I want.
laughingcreek
using offset on these faces so the bodies overlap may allow you to combine the bodies into a single body and close the gaps.  hard to say.  if you attach your .f3d we can probably give you other ideas
testjig
I've tried to offset some faces, but Fusion would not compute it.
I'm attaching the file I'm currently working on, I've tried so many things, currently trying to do only a few section at a time, then combine them, but I'm getting some gap and the front sphere does not compute when I extrude to object.
testjig
I'm currently retrying to do surface offset, I haven't work with surface yet, but it seems to do the trick if I select each external face individually, I can't select too much surface as fusion would give me an error, but that's one step in the right direction
etfrench
Make it in several sections:
Add bracing to the fixture to make it stable.
ETFrench
testjig
Thank you for your help.  Doing it in section and bracing it would've been a good solution, however, I was looking for a more universal way to do this, because I know I'll have to do it again for other product.
If anyone interested, the solution I found was to make a "surface offset" of 0mm for all external surface, stich all those surface together, patch the gap left by gap between parts and then patch the top to create a body.  Then use that body as a tool with "combine/cut".
