Make a diameter-dimension in a sketch
christian.akesson
Observer Observer
Message 1 of 18
christian.akesson
Observer
Observer
When making a revolve I always want to dimension most of the geometry as diameter.
I can make a symetric point on the other side and use it to make a dimension that is double the distance of the radius.
But is this really the only way to do it in Fusion360?
Replies (17)
Message 2 of 18
eellenburg
Message 3 of 18
christian.akesson
Observer
Observer
Thank you for the solution.
In your video you are using a construction line as center-line.
But it works with a regular line too.
Perfect!
Message 4 of 18
Does anybody know why this 7.0 in Dia dimensional line is not connected to the sketch line itself.
Message 5 of 18
dieselguy65
you mean that top line with the 7 inch designation?
its not part of the sketch, its the dimension of the sketch.
its not supposed to be connected to it
Message 6 of 18
Take a look a the video above again please. It is supposed to be connected.
Message 7 of 18
dieselguy65
there is no 7 inch line in your video that i see.
those sketch dimension lines shouldnt "connect" to the sketch, they arent part of it, just dimension
Message 8 of 18
Perhaps I used the wrong word. Not "connected" but "in-line/Collinear".
This has been resolved in other post.
Message 9 of 18
What it should have been - Right vs Wrong. (See attached pics)
Thanks to @laughingcreek in another post.
I'm new here so have not figured out how to quote another post.
I thought I tagged him here so any one running into this issue could find solutions.
Thanks everyone.
Message 10 of 18
Sure wish they would have added a hotkey... have to right click EVERY time and if you go to fast it breaks the workflow.
Message 11 of 18
dieselguy65
Added a hotkey, for the dimension command?
You mean like pushing 'D' key on keyboard.
Or assigning a spare mouse key to it.
That's what I been doing.
Brian.
Message 12 of 18
laughingcreek
I think he means for creating a diameter dimension, you have to right click to bring up the marking menu-
Message 13 of 18
TheCADWhisperer
@Anonymous
You are picking the lines in wrong order.
Always pick the center line first.
Pick Order 1 and then 2Pick Order 1 and then 2
Message 14 of 18
laughingcreek
hopefully in the 3 years since @Anonymous  posted the original question he has figured it out.
Message 15 of 18
No, to toggle to diameter dimension. In Inventor you can actually define a line as a center line and all dimensions snapped to it are automatically set to diameter.
Message 16 of 18
TheCADWhisperer
@Anonymous wrote:
In Inventor you can...
The Fusion 360 3D CAD design app is the new metaphor for >>designing differently<< and efficiently.
Message 17 of 18
nathanstryon
Observer
Observer
Any new way to set diameter measurement as the default?
Message 18 of 18
HughesTooling
There's now an option to create a centre line in a sketch. Dimensions from this will all be diameters.
Mark Hughes
Owner, Hughes Tooling
