Magically moving joint?
robduarte
Message 1 of 9
robduarte
Hi all, I'm trying to create an as-built joint and immediately after creating it, its position jumps over to a new location. I know it's got something to do with having moved components, but I can't figure out how to resolve the issue. I can provide the design file but I'm hoping someone has some answers just by looking at the screencast: https://youtu.be/qEIlt6HXWAY
Thanks for any help
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
Replies (8)
Message 2 of 9
robduarte
Ugh: if I edit the joint, delete the Position, select the position (center of the axle) again (same way I selected the position when I created the joint), then click OK ... it stays in position without jumping as it did in the screencast. I'm going to call this a bug unless someone has some other explanation?
An updated screencast: https://youtu.be/xVBnQ1rGL80
Rob Duarte
Twitter | YouTube
Message 3 of 9
TrippyLighting
@jeff_strater we've seen this over the weekend as well. This is another example.
Message 4 of 9
TrippyLighting
@jeff_strater I've seen this over the weekend here as well. @robduarte's design is another example.
Message 5 of 9
daniel_lyall
There is a couple of guys on the fusion user's facebook group haveing the same problem
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 6 of 9
jeff_strater
Yes, this is definitely a bug.  @robduarte, is there any way we could have this design, so we can investigate?  It is strange that an edit will fix it.
@TrippyLighting, I think this is a different problem than in Saeed's post, because in his case, As-Built worked, but regular Joint did not.  But, there is clearly something wrong in both cases.
Jeff
Jeff Strater
Engineering Director
Message 7 of 9
TrippyLighting
@jeff_strater nope, same thing. See screencast. Model attached.
If I pick the revolute part on the link it fails. If I pick the revolute point on the base it succeeds.
Edit: You mentioned in Saeeds thread that the assembly behaved wonky. This is what I though you meant.
Message 8 of 9
jeff_strater
filed as FUS-33516.  Thanks for reporting this, and sharing the design!
Jeff
Jeff Strater
Message 9 of 9
jeff_strater
This bug has been fixed in our internal builds.  It should appear in an upcoming update.
Jeff Strater
