lost all my new projects!!!
wl_kicker
Message 1 of 27
wl_kicker
after updating the new version of fusion 360 yesterday! version 2.0.1365! all projects i have modeled are disappear!  how can i get them back!???? so sad ! i worked on one design all day long!! after 3d printing it ,i needed just a little adjustment it will be perfect ! but i can't find the model! before i closed the fusion software , i pay attension to the saving result ! i saw it showed on the files panel!
Replies (26)
Message 21 of 27
ryan.bales
Autodesk Support
Autodesk Support
From what i can tell you are part of two different accounts. Both of which you are an admin on, I PM'd you the emails for each account, as @Phil.E mentioned its more than likely after the update you logged into a different account than the projects originated on.
Ryan Bales
Fusion 360 Product Support
Message 22 of 27
ryan.bales
Autodesk Support
Autodesk Support
Were you able to test both logins?
Ryan Bales
Message 23 of 27
3dsolis.store
some problem ı have can you solved ?
Message 24 of 27
jhackney1972
This thread is from a user that had created two different Autodesk IDs.  If you did this, and you are not seeing your files from one of your Autodesk ID, go to this site, log in with that Autodesk ID and you will find your files in the Fusion 360 icon on the lower left side after you log in.
This is a Duplicate post as this one.  Please do not double post!
John Hackney, Retired
Message 25 of 27
a_aizpuruVDA3S
hello  wl_kicker,
I am in tne same situation. I have been talking with a machine and I have done several trials to solve the problem following the proposals made by a machine but I have not been able to recover anything.
Message 26 of 27
Phil.E
This thread addresses an issue where customers create new login ID/password and then cannot find the designs associated with their previous login ID/password. Has that happened to you?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 27 of 27
a_aizpuruVDA3S
Hi Phil,
Yes.
I was using the education e mail and the old designs were related with my
personal email.
Aitor
