Looking for a way to convert facets to smooth curve after mesh conversion
Julie_7
Julie_7
I have a free license, so my conversion from mesh to body is limited to using the faceted method.
After I convert to solid body, I then delete facets on flat surfaces to clean up the body.
What I need is a way to somehow turn curved features such as holes into a surface instead of hundreds of facets.
In one case I drew a sketch of the curve on the top surface and then extruded the sketch to remove the cutout. Then I used to same sketch to extrude the cut. Sadly, the facets came back.
Using the above image, if I could convert the facets around the peg to a smooth surface I would be happy. I could then extrude to remove the fillet at the end of the peg.
TrippyLighting
In that case it might be easiest to re-design the object with the native tools in Fusion 360.
Can you share the model/.stl file ?
jhackney1972
Take a look at the Blog Article and Video.  It works well on STL models that have sharp features.
John Hackney, Retired
Julie_7
I have already redesign the model using dimensions from the conversion. I am just trying to learn better ways.
TheCADWhisperer
@Julie_7
In that case, “Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply?”
