Creating Reusable "Design Tools" with Parametric Timeline
jb9784
jb9784
Hello Forums!
Is it possible to create "design tools" using the parametric functionality of Fusion 360 to automate simple, repeated processes?
I'm working on a project where I create models out of stacked cardboard slices.  As part of the design process there are lots of simple repeated tasks - move body here, rotate body about this axis, slice body at this width...  I'd like to automate these processes if possible.
Here is an example
- I have an arbitrary body that is saved in Design A
- I have a "tool design" that completes some simple change - in this example let's say that it is "Slice body into 1 cm segments"
- The tool design has the following steps in the parametric timeline:
>> Start with a Body
>> Create a sketch, add a 10 cm line at an arbitrary position
>> Split Body using that line
>> Rectangular pattern the split feature 10 times
- The result is that the Body is split 10 times.  I can now save this as a new design.
How can I import the body from Design A into the "tool design" so that the parametric timeline completes these steps?
How can I reuse the "tool design" so that I can import bodies from Design B, C, D... and leverage the "tool design" as a slicer?
I think this can be done with scripts, but I am not a developer and am looking for a no-code or low-code solution.
Thank you!
jhackney1972
The method used in the Blog Article and Video my suit your needs and ideas.
John Hackney, Retired
