Lofting help
Lofting help
barkster
Message 1 of 13
Lofting help
barkster
I am trying to create a mat that is shaped similar to a sole of shoe, I am trying to make it flatter on one end and curved at the other end.  I don't do much work like this but I've jacked around with this and can't figure out a way to make it the shape i'm looking for.  I'm probably over complicating this.  Any help would be appreciated.  Here is the screen shot of the profile I'm after along with the file.
Replies (12)
Message 2 of 13
aliobidi
Hi ,
something like this ?
your file below
Message 3 of 13
aliobidi
or maybe this
Message 4 of 13
barkster
no I want it to follow the shape down the middle
Message 5 of 13
TrippyLighting
There are important constraints and dimensions missing in your base sketch. Before moving to advanced topics such as lofting I would recommend you get the very basics straight!
Message 6 of 13
aliobidi
added some sketch for rails
Message 7 of 13
barkster
Yeah that's what I'm after can you show me what I was missing. Thanks
Message 8 of 13
barkster
thanks you don't have to constrain to make a model, you are assuming things.  Please don't respond to my requests, they are never helpful.  Thanks
Message 9 of 13
aliobidi
your file below
see the timeline and ask me if you have any question
Message 10 of 13
barkster
I appreciate the help.
Message 11 of 13
TrippyLighting
I believe you are pretty alone in your assessment that my replies are never helpful. They might sometimes be inconvenient ...
Garbage in, garbage out. If you don't properly constrain sketches you'll get into all sorts of trouble with your models.
Missing tangency constraint will at some point in time hider progress, particularly with lifts.
If you don't want to learn and slap stuff together sloppily I am OK with that, but the question is not if stuff breaks, the question is only when!
Message 12 of 13
barkster
The last time you responded to a question on mine you were zero help, did exact same thing again. You critique the person and don't provide any help.  Why are you wasting your time? This post was created because I was just trying to figure out the how to create a shape, not how to constrain a sketch. You assume people don't know what they are doing. The other person provided help, you didn't. I asked nicely for you to not reply to my posts.  Thanks
Message 13 of 13
TrippyLighting
@barkster wrote:
... You critique the person and don't provide any help. ...
Telling you that the sketches in your design need to be properly constrained is not personal, and that is exactly the help you need!
You are correct that I could and perhaps should have created the loft you are looing for.
I can create a screencast later and show you how that is created.
Perhaps than you see why constraining is so important!
