Hey All,
I am still very new to this. Just trying to create the bottom corner of the rudder. Please see the attached vid.
Thanks in advance!
Link to the project if that helps.
Edit: Second attempt to add the vid.
Solved by jhackney1972. Go to Solution.
please share the file
File > export > save as f3d on local device > attach to next post
günther
Here you go...
I added a line across the top to make that bottom section a closed surface. But still can quite get it to do what I want.
Thanks again.
Change the two middle sketch lines to Construction and then Loft with a Rail. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
