Loft in not working to make a nose
matt_bolty
Message 1 of 8
matt_bolty
I am following a tutorial on making a 3d model of a boeing 757. I have hit a bit of a snag which is driving me a little mad with lofting when making a nose cone.
I have made the fuselage minus the nose cone and converted the body into a component. The tutorial deleted the original body and so did I - which may have been a big mistake! Because, when I projected the flat front of the fuselage from the body, it gave me a single curve with no points. But now I am re-doing the nose, I projected from the component and it has several points. And there seems to be no way of converting this into a single curve which in itself seems ridiculous!
When I try to loft, I click the three profiles as show in the photos and before I hit ok, I get no warnings and it does seem like it will work. But when I hit ok it throws the error: "1 Reference failures: Closed profiles can not be coplanar for a loft" and "compute failed". It used to work perfectly when the projected curve was one line but now it just won't.
Any suggestions? Thank you in advance!
Replies (7)
Message 2 of 8
jeff_strater
If you can share the file here, it will be easier to help you.  But, a couple of strategies to consider:
  1. the nose (in fact, the whole plane) is symmetric along the length of the body.  Just model 1/2 and mirror it.
  2. use Loft to a Point (by selecting just one point for a profile), and set the type to tangent.  That's how I always model any kind of rounded "nose" shape.  You can add rail curves for better shape control
Jeff Strater
Engineering Director
Message 3 of 8
matt_bolty
here you go! I just don't understand why it worked when I projected off a body and not a component agh
Message 4 of 8
wersy
Split the profile and use only the half.
You need also a rail.
Message 5 of 8
matt_bolty
thank you! I'm having a worse time of it with airfoils now - trying to add a wingtip and oh my god it refuses to work haha. works fine if I design my own with point splines but if I import a NACA DAT file it just refuses. Maddening!
Message 6 of 8
wersy
If you show us both versions, we can figure out what the problem is.
But please create a new topic for this.
Message 7 of 8
matt_bolty
will do! posted the first issue already. Airfoils are very tricky! As is creating perpendicular planes from inclined planes - all in the post
Message 8 of 8
wersy
I don't understand what kind of issues you have with airfoils.
You already posted it?
