- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am following a tutorial on making a 3d model of a boeing 757. I have hit a bit of a snag which is driving me a little mad with lofting when making a nose cone.
I have made the fuselage minus the nose cone and converted the body into a component. The tutorial deleted the original body and so did I - which may have been a big mistake! Because, when I projected the flat front of the fuselage from the body, it gave me a single curve with no points. But now I am re-doing the nose, I projected from the component and it has several points. And there seems to be no way of converting this into a single curve which in itself seems ridiculous!
When I try to loft, I click the three profiles as show in the photos and before I hit ok, I get no warnings and it does seem like it will work. But when I hit ok it throws the error: "1 Reference failures: Closed profiles can not be coplanar for a loft" and "compute failed". It used to work perfectly when the projected curve was one line but now it just won't.
Any suggestions? Thank you in advance!
