Local Turntable Render No Longer Available
Message 1 of 10
When I try to do a turntable render. I no longer have the option to do it locally after the latest update. Am I doing something wrong or is this no longer available now that I just have "BASIC"
Replies (9)
Message 2 of 10
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting. Smiley Happy
I'm aware of it has been supporting on cloud. For sure, I've already asked other experts it. if I received any response, I'll get back to you. please give me more time! Smiley Embarassed
thank you for your warm understanding.
Many thanks.
Message 3 of 10
anandjoshi
Hello Dave,
Turntable render is only available using cloud render and not local render since its inception. So we never supported local turntable render.
Hope this helps.
Anand
Message 4 of 10
So paid subscribers have to pay more to render turn table views? Something that other application support for free.
Message 5 of 10
Hi
Your response makes no sense. Turntable rendern simply turns the object along it's y axis and renders that view. Then it stitches those together.
If you can render one you can render 36.
I do not have a amazing internet connection but a solid workstation which can easily handle these workloads. I hope you can add this feature in the next update
thank you
Message 6 of 10
speedfreakgarage
@anandjoshi @ahreum.ryu  Not being able to render turntable animations locally, is unacceptable.  When will we get a local render option?  We pay for this software.  Forcing us to use cloud credits is highway robbery.
Message 7 of 10
TrippyLighting
@speedfreakgarage I wonder what quality of turn table render would be acceptable to you.
Even the cloud turntable render only allows 36 frames so 1 frame every 10 degrees. That is not even hobby level.
My suggestion would be to export your model as a .fbx and do the turntable render in Blender. With a little luck and if the object lends itself to it you can do that in Realtime using Blenders Eevee real time render engine.
For turntable renders a purely CPU based render engine is really not the right tool!
Message 8 of 10
speedfreakgarage
I like using Cycles in Blender. But I stand behind my point that turntable
rendering should be available locally in Fusion.
Message 9 of 10
that is just sad
Message 10 of 10
Juan_Pierre
the more I use fusion the less I want to use it.
