Local Render and cloud render are different....
PhilProcarioJr
Mentor Mentor
Message 1 of 49
PhilProcarioJr
Ok this drives me nuts, why does the local renders look different then the cloud renders?
You can see the white dashed lines at the bottom corners...then the white highlights on the floor around the feet......
This needs to be fixed, it shouldn't make any difference other then time to render between local and cloud rendering.
It appears that the local render uses a polygon lower resolution mesh then the cloud uses..........You can actually see faceting at the rounded edges on the local render but not on the cloud render.......
Local:
Cloud render:
Issue:
Phil Procario Jr.
Owner, Laser & CNC Creations
Replies (48)
Message 2 of 49
TrippyLighting
I've notice a difference in results between cloud and local render as well. Also with the white plastic that has SSS enabled (translucency).
Message 3 of 49
colin.smith
Hi @PhilProcarioJr, I agree, they should be the same.  I'm going to have someone from the visualization team take a look.
Would you be willing to share the file?
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
Message 4 of 49
PhilProcarioJr
Yes I will share it with one of the dev team members, just let me know their email addy.
You can even tell the shadows are very different....now given the fact that I was told this is a physicaly based render there should be no differences.
I would assume the only real difference there should be is my local render uses one cpu and the cloud render uses a bunch...given the results I'm starting to think this is not the case.
Phil Procario Jr.
Message 5 of 49
chengyun.yang
Would you please share your model with me? My email address is chengyun.yang@autodesk.com
Chengyun
Fusion Development Team
Message 6 of 49
PhilProcarioJr
Sent invite
Phil Procario Jr.
Message 7 of 49
chengyun.yang
Got it. Thanks!
We will look into it.
Chengyun
Message 8 of 49
PhilProcarioJr
Here it shows how different the renders are....
Local:
Cloud:
Phil Procario Jr.
Message 9 of 49
PhilProcarioJr
Here you can clearly see that local renders use a lower resolution mesh, the holes appear poligonal and in the cloud renders they don't.
Local:
Cloud:
Local Hole:
Cloud Hole:
And you might be saying well just do cloud renders then.....well this is a major problem when I don't have internet access and I have deadlines for product renders....
Phil Procario Jr.
Message 10 of 49
PhilProcarioJr
This is yet another reason I said in a past post that you are not exposing all the parameters to us...for the novice user that's fine, but if you want Fusion to be production ready then it needs to compete with the competition and its things like this that make community members vocal about it not being production ready. Pro users NEED more control...period. If this is a performance issue let me decide how long I want a local render to take. Don't do it for me because you don't know what I want. Give me a resolution control for the rendered mesh...a button for coarse, medium and fine, like you do for exporting stl files for rapid prototyping. And if this level of control is already available Please document it, because I looked everywhere I could find info on rendering and saw nothing on this. Fusion is a great piece of software don't hold it back because of the novice users, anyone getting into CAD has a long journey ahead of them that they either want to take or they don't. You can't kiddie proof a tree shredder. Smiley Wink
Phil Procario Jr.
Message 11 of 49
TrippyLighting
Could not agree more! Don't over simplify the UI and limit accessibility to advanced features.
Expose them to experienced users that know how to tame the beast.
Message 12 of 49
fulcrumusa
Exposing all the available options/commands/tools, etc. also has an educational value. I can't count the number of times where I've been missing around in Fusion (or any tool/software) and, while looking through the menus, though "Ooh, what does this command/option do?"
When facing a lack of documentation [I've read many posts where users are complaining about such a lack], expose all the options and let the users try them all. Don't underestimate how smart and savvy we are. We can figure stuff out!! 🙂
Message 13 of 49
chengyun.yang
Hi All,
Thanks for the feedbacks. About the tessellation quality issue, it can be worked around but we do understand it is not obvious to the user how to do that. What you need to do is to zoom in on the problematic part(s) of the model while in GPU rendering mode and then enable ray tracing. Zooming in means a finer LOD is chosen and once that has been used in ray tracing it will still be used even if you zoom out again to see the whole model. The key here is zooming in before you enable ray tracing because we don’t allow any tessellation update to happen while ray tracing is enabled since that would lead to “stalls” when rebuilding the internal acceleration structures for ray tracing. I will bring this issue to our product design team to see if we can do some improvement soon.
On the other hand, Fusion is going to release a new local rendering feature(Probably in March major release) where we will allow you to do the local rendering in the background, as a complementary/additional solution to the existing viewport and cloud rendering. When that is ready, there will be more options to control the rendering quality and performance. Please stay tuned.
Chengyun
Message 14 of 49
PhilProcarioJr
@chengyun.yang
Thank you for explaining how to fix the tessellation issue. Much appreciated.
Honestly, that's a bad way to handle it, just give us a slider or a button please.
This is another piece of information that should be in the documentation because it will be lost on the forums in a week or so.
Phil Procario Jr.
Message 15 of 49
PhilProcarioJr
Why are the cloud renderings so grainy? I have set everything as high as I can find in the settings yet the quality is still poor. Look at the nylon nuts.
Phil Procario Jr.
Message 16 of 49
TrippyLighting
It's the SSS component (Translucency) in the Nylon material that takes much longer to resolve than the rest of the obaque materials in the scene. I believe that is a trait that all PBR share.
The best way to counteract this I've come across is selective/region rendering that would allow a user to comtinue rendering only a specific area of the image, the nylon bolts in this case.
Message 17 of 49
PhilProcarioJr
I don't have this problem with local renders only cloud renders and you don't control how long the cloud renders iterate only local renders.
I would do a local render of this but the render of SSS materials is all wrong and looks terrible.
Phil Procario Jr.
Message 18 of 49
PhilProcarioJr
@chengyun.yang
Also I noticed the tessellation issue / fix doesn't work on large assemblies. I can zoom in on a problem area but then another area is to far away and if that area is in the shot then it looks bad.
more comparisons between local and cloud.
Local Render-Lighting and material is terrible, also if you look at the bottom right corner there is the tessellation isue, even though I was zoomed way in on it before turning on raytracing:
Cloud Render-The lighting and material look just like the real thing....the graininess is killing me.:
Phil Procario Jr.
Message 19 of 49
PhilProcarioJr
@chengyun.yang
Here I zoom as far in on the bottom plate, then turned on ray tracing and as you can see on the bottom left corner of the plate it still shows the tessellation issue. Have you guys gotten the chance to look into this issue? It's harder to see on this render but when I render it larger resolutions it very clear.
Phil Procario Jr.
Message 20 of 49
PhilProcarioJr
Here you can clearly see it, I zoomed all the way in on the plate then turned on ray tracing and zoomed out and let it render for 1000 iterations.
Phil Procario Jr.
