Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Little loft issue
6 REPLIES 6
eric.thepaut3
298 Views, 6 Replies
Little loft issue
Hello, i made a curved loft, and i see a straight line i should not have that is not on the other side, though the profile is symetric. What is wrong ? Here is the file https://a360.co/2TaZL7S
6 REPLIES 6
LeonardoBN
in reply to: eric.thepaut3
Hi @eric.thepaut3. Does your object has a symmetry? Your bottom profile seems a little bit off center.
Leonardo Brunelli do Nascimento
Chemical Engineer
LeonardoBN
Your first profile is OK, but here is the difference of bottom profile:
Then your shape becomes:
Chemical Engineer
eric.thepaut3
in reply to: LeonardoBN
Sorry but i don't see... You add a center point constraint? To what ? I'm too newb, you must tell more...
LeonardoBN
Sorry not being clear before.  😶
You defined well the first sketch (the main straight part), and it has symmetry.
In the second sketch, you could project that center line for symmetry (or create a new one on this skecth). Here you could draw one side of yout shape (one line and one spline) and then Mirror them. As you used spline, surely the other side will be symmetric.
You can use symmetry here, and add appropriate constraints to help you.
But...here I didn't delete anything; I just added a point to show you the small difference that caused you Loft issue. Then I added a Coincident constraint between this point and the center line (your construction line). There are other means you can achieve the same result, though.
This is your design, with the point I mentioned.
Or...you could loft one side to create half of your shape, and mirror the solid body.
Chemical Engineer
eric.thepaut3
Yeah great ! I saw a point was not really on the line! Thanks!
Can you mark one answer as the solution ?
