Linked Components not updating properly
adam.filipowicz
adam.filipowicz
Running into issues where I insert a component from my library. then I open up to edit that component and make a small change..
when i go back into my main file.. it asked to update links since it change.. but the updated component is quite right some parts have moved or disappeared..
when I double check and open up the component again.. it looks fine..
jeff_strater
Hi @adam.filipowicz,
One thing to be aware of:  Fusion store "overrides" in the top-level assembly design for things like component position and visibility.  So, if the change you made to your sub-assembly is only to component visibility or position, the top-level will keep its own overrides and will not update to those in the lower-level referenced components.
I'm not saying that this is your problem, it's hard to say without seeing the design itself, but just something else to consider.
Jeff
Jeff Strater
Engineering Director
