Move a sketch to be coincident with another sketch
Hi-
Here is two sketches. The lighter yellow is the FRAME.
The darker yellow is the CAGE.
Bother were completed, and the drawing moved forward to other design elements.
I discovered that I need to lengthen the Frame 1". Which I did with no problem.
Now, I must move the Cage so the rear tip is in line with the tip of the Frame--shown by the two arrows.
I've been futzing about for a while and cannot figure out how to do this.
NOTE: there are many components attached to the Cage...may I assume all will "move" (find their correct places in the design) with the Cage after the cage is moved?
Thanx
-G
points.jpgh
points.jpgAnother angle below.
TrippyLighting
Please share your design  by exporting it as a .f3d and attaching it to your next post.
You can also share a public link by right-clicking on it in the data panel and selecting "share public link".
So...anyone? Iss it possible to move the sketch to match the new position of the body/component?
TheCADWhisperer
Are you dimensioning your work?
What happens if you hit P for Project Geometry and project point from first sketch into second sketch and then apply a coincident constraint?
1) GREAT screen name! (I tend to scream and shout and use all sorts of language that could make a linebacker blush--but, I don't throw things).
2) Forgive me: what's Dimensioning? I mean, I probably am, but I'm not really with it with a lot of the correct terminology/vernacular.
Your suggestion seems do-able except it doesn't accomplish my intention--(I know, I didn't explain why I want to move the sketch).
I drew a sketch.
Proceeded with the project.
Much later, the section that is projected from that sketch needed to be moved an inch toward the rear end.
Now, any time I need to go back and do something pre-move, I have to contend with the moved section that has--by virtue of the timeline--been relocated to its original position (an inch toward the front.
At this point this is more of an inquiry to quench a thirst of the unknown. So, not a huge deal.
But thanx for your time/suggestions.
-G
