- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Blank drawing, create a sketch on the XY plane, edit sketch.
Draw a line ('A'), then offset that line an arbitrary distance -line 'B'.
Draw a perpendicular line from A to B.
Break line A -- automatically selects intersection of the perpendicular line, as expected.
Problem 1: part of line B is removed (what?)
Problem 2: I can't move either piece of line A that supposedly was broken. Can't even point-point move in the same sketch. I can delete it. I can offset it, then delete the A piece. This would serve my purpose here -- except the mating B piece below is missing ☹️
Repeat above, but just two parallel lines with the perpendicular. In this case, everything the same except break doesn't remove the 'B' line piece.
What's happening here?
Thx
K
