just to be clear there is no confusion about units. There are only two choices in Fusion, mm or inch. The DXF export file inherits the same units as the model.
The problem I describe is that Fusion is doing a 10:1 scaling to fit the model as a drawing, and yet when the recipient of the DXF file opens the file their software is not recognizing the scaling and it appears to the recipient that the true model size is 1/10th the size that I intended.
The whole point about exporting a file is that the recipient can use my model without the recipient having to use CAD to recompose the model with the possible inaccuracies and time penalty that incurs. One would imagine that DXF being an Autodesk format and such a widely used format throughout engineering practice that for two businesses to swap files without confusion or inaccuracy would be commonplace.
There have been several recommendation that I export a DXF of a sketch.......but WTF. The part that I want the company to laser cut is 3D, and I have a model of it. Whats more, Fusion does a nice job a drawing an engineering diagram that I can dimension to my satisfaction. It would appear however that any scaling required to compose the drawing is not transmitted to the file and therefore the recipient of the file has no idea either. That seems like a fault to me.
I will try using the ANSI standard as opposed to the ISO standard and see what happens.
Craig
