lines in drawing mode are sometimes dashed and sometimes not
Hello there.
When I activate my sketch in drawing mode, some of the lines are dashed and some of them are not.
Can anyone explain to me why this is the case, am I doing something wrong?
In construction mode all lines are just lines not construction lines.
The red rectangles should visualize which lines I want to be dashed.
thanks
-Yannick
HughesTooling
As far as I know edges of solid bodies are continuous and all sketch lines are dashed. Short line sections of a sketch might appear contiguous just because of the length of the dashes.
Mark
Mark Hughes
Owner, Hughes Tooling
AgileJohns1411
Did you find a solution for this problem with dashed lines as solid lines in drawing?
Please share your experience and I am facing the same issue in my project.
jhackney1972
Fusion 360 shows all model sketch lines as dashed.  This is the way it has been all along and cannot be changes at this point.  You will not find any way to change this fact.
John Hackney, Retired
