I am creating a wooden box to store canned goods for an emergency.
I can see all solid components when I select the top level assembly. Fig 1.
I then create a new component (Left Side Plywood) and add a new body to it. When I select and make "Left Side Plywood" active, I see the component I just created and a wireframe or x-ray type view of the rest of the assembly. Figure 2.
The issue is that when I want to do a point to point move of the new "Left Side Plywood to move it to a certain point on the main assembly. The multiple layers "wireframe/x-ray" image makes it difficult to find the proper destination point. Figure 3.
It is especially challenging when there is many components displayed and I am trying to locate the correct point to move it. Fig 3 again.
I checked the "Display Settings --> Visual Style --> Shaded with visible edges only" and it didn't work.
Here is the software version information.
2.0.9930
Active Plan: Fusion 360, Personal
Windows 10 (19042)
Lost and confused
Figure 1
Figure 2
Figure 3
Solved by g-andresen. Go to Solution.
I unchecked it and is is working the way I want now. Thanks for the solution!
