Line left on object after revolving
olafserdmann
Message 1 of 25
olafserdmann
Hey everyone,
I am fairly new to Fusion360. After revolving the inside of a plant pot I am designing, the sketch line is imprinted into my object, and it will show when 3D printing. I attempted everything I have seen online but that simply won't go. Any suggestions would be greatly appreciated. The line in question is the sole black line on the inside of the pot.
Thank you in advance.
Replies (24)
Message 21 of 25
g-andresen
@JDMather wrote:
@g-andresen
I don’t know what this means?
What does "this" refer to?
günther
Message 22 of 25
TrippyLighting
@g-andresen wrote:
@JDMather wrote:
@g-andresen
günther
I believe "pulling registers" is a direct translation form German that doesn't work in English.
It might translate to "pulling out the stops".
Message 23 of 25
g-andresen
@TrippyLighting wrote:
@g-andresen wrote:
@JDMather wrote:
@g-andresen
günther
Thanks for the hint.
günther
Message 24 of 25
wersy
Just print this solid in spiralvase and see what happens.
Message 25 of 25
TheCADWhisperer
@olafserdmann
You can avoid that curve by using tangent lines/arcs rather than Spline in your Revolve profile.
If you want Spline then you will have to Save as Mesh (not Export) as high resolution and then Remesh.  Did you figure all this out?
