line dimensions
line dimensions
whittakerdw
Message 1 of 14
line dimensions
whittakerdw
When I draw out a horizontal line in a sketch and type a dimension, the line locks at whatever dimension I drug it out to instead of extending out to the dimension that I typed out. If you notice in the screencast it worked properly once but when I hit the green check mark the line disappeared. This is the first time I have noticed this and I was wondering if anyone else was experiencing this or had a solution.
Replies (13)
Message 2 of 14
whittakerdw
I forgot to add the screencast
Message 3 of 14
JHRendon
Can you upload a video or screenshot when that happens?
Message 4 of 14
whittakerdw
I forgot to insert it the first time but it is attached now
Message 5 of 14
JHRendon
Pretty weird. Make sure your keyboard works correctly. I could see the dimension with "4 in"  was done correctly.
you should only press "tab key" when you want to add the angle and finally, enter.
Message 6 of 14
whittakerdw
Even when I enter the dimension and press enter it does the same thing.
Message 7 of 14
JHRendon
Idk what happens here. Can you try this in another CAD software or even writing a document or this only happens in fusion 360?
Message 8 of 14
g-andresen
This is currently a problem especially with W 7.
My recommendation:
First create the elements without dimensioning and then assign them with the dimensioning tool.
günther
Message 9 of 14
whittakerdw
@g-andresenIs this something that is being worked on that you know of?
Message 10 of 14
whittakerdw
This is only happening in Fusion 360. I have been working in other CAD software but I went to make a 3D model of a 2D drawing and that is when I noticed this.
Message 11 of 14
g-andresen
look here
günther
Message 12 of 14
JHRendon
Well, checking what @g-andresen  said, maybe it is better if you get another windows version. 🙁
Message 13 of 14
Phil.E
@whittakerdw That is not surprising. All applications have different requirements.
Windows 7 is no longer supported by Microsoft or Fusion 360. There is no plan at this point to restart support for Windows 7 in Fusion 360, meaning this will not get fixed. It would be best to start planning a transition to Windows 10.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 14 of 14
whittakerdw
@g-andresenthat seemed to do the trick. Since this is a work computer, I do not have the authority to download a new version of windows but I will see if I can since Fusion is no longer supported on Windows 7. But in the meantime this seems to work. Thank you for that.
