Line at top of shaded view
gkore
Message 1 of 11
gkore
New user to Fusion 360 and I seem to have a line that appears in my drawing above my isometric views.
I have tried turning of bodies/components with no changes. Does anyone know why this happens?
Replies (10)
Message 2 of 11
dsouzasujay
@gkore
You can attach the F3D/F3Z file here?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 11
gkore
Here you are
Message 4 of 11
dsouzasujay
Hi @gkore
I was not able to see any any issue on my machine or may be im missing a key step.
A screencast/video of what you are doing will help me to understand the problem.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 11
gkore
I will figure out how to take that but its literally as the screenshot shows.
I am creating drawing and there is a time above my drawing that will no go away. Not sure what is causing this
Message 6 of 11
HughesTooling
@gkore  If you export the 2d drawing we can see exactly what you've created. If you view the 2d drawing's details on web you get the option to download the Fusion design as an fz3, this will contain the part and the 2d drawing.
Click the version number in fusion's data panel to get the option to view on the web.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 11
gkore
It seems to happen regardless of the project
A line above my drawing views
Message 8 of 11
laughingcreek
it COULD be a bug.
it COULD be something your doing.
since nobody else can recreate the problem, there is no way to tell which with out a screen cast from you or the drawing exported as a .f3z
Message 9 of 11
HughesTooling
Does the line show if you save the drawing as a PDF?
Mark
Mark Hughes
Message 10 of 11
gkore
I would but I really should not be sharing this information the client would not like that
Is there a way to update?
Message 11 of 11
laughingcreek
you did say it doesn't matter what project your using, can you not export a drawing in .f3z format of a dummy project?
