Learning move, import, cut, orientation and positioning with snap.... how to
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day
I am an Acad hobby user looking to become perfect continuity on lofted surfaces created from spline constructions, my preferred creation method.
The forms are organic combined with mechanical parts.
I have give it a try in Inventor but Fusion definitively convinced me better. Less complicated and the orientation between planes is more userfriendly as in inventor for me.
In Acad i use to construct things taking orientation direct from the splines that i form related to the positioning that i do in the 3 d environement. Orientating i do by typing or activating the snap commands that i need, in free orbit cam.
At the moment i am learning and starting take confidence with fusion.
I have try to import as igs step and sat, it seams to not import 2d at all.
I am here to ask for 2 things, first of all i am tryng to import splines from acad.dwg/step/igs to prevent that i must construct all again in fusion.
The first question is, what filetype have i to import in fusion to have also the splines if it is possible? (I need them to reconstruct it by using T splines). Or what method do you suggest if i already have the lofted surfaces from acad.
I was thinking to loft it in acad even if i not have perfect continuity, cut the surfaces following the splines, after cut it take the edges to reconstruct them with same shape and intersection points.
My other question is, how to import sketches or creations made as 2d in acad (mechanical) to use them as reference in the sketch that i need to position at his place and need to be in relation to the loft guides that i wanna create?
First pic is an older grip, stitched to become it solid.
The other one is the actual one i am making, taller, smaller, no socket and adapted to another trigger mechanism.
Any kind of suggestions are welcome.
PS: i am looking for a good snap and move tutorial in 2d and 3d environement, if anyone can link me to a good one that allows me to understand how move and position better like i can do easy in acad i would be happy. Thank you in advance.
