Sketch dimension locking bug
Willa1980
Willa1980
Hi there,
since the last 1 or 2 updates, the sketch dimension lock behaviour changed to something strange. Here are some screenshots of the issue. I enter a dimension (2.5), then I press TAB to lock this dimension. I click onto the point where the line should end, but suddenly, the locked dimension changes to 2.575 .
I guess this is a bug.
Willa1980
martin.zatecka
I'm not sure how to reproduce it, please would you share your design with me?
regards
Martin Zatecka
UX Designer
Willa1980
Here is a screencast. It is very easy to reproduce: Snapping to objects seem to have higher priority than the dimension lock. This shouldn't be the case:
https://knowledge.autodesk.com/community/screencast/a0345af7-4142-4689-8e55-dc3626059b18
martin.zatecka
thank you, I logged a defect.
regards
Martin Zatecka
UX Designer
Willa1980
Will this be fixed some day?
martin.zatecka
Thank you for reporting the problem. I verified the defect. It was closed as not reproducible. The first scenario is really not reproducible on our developer build of Fusion, the second case mentioned on forum is still reproducible on dev build. Probably the issue is more complicated to reproduce based on situation or settings.
I already reopened the defect and attach new example.
regards
Martin Zatecka
UX Designer
