Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Fusion 360?
(List below shown in chronological order - scroll down for solutions posted in 2016.
Click HERE for solutions posted in 2017)
ARCHIVE
January 2016
Error Duplicate Headers Received From Server when downloading Fusion 360
Error during launch, “The application has encountered an unexpected authentication error ...
Fusion 360 has installed but will not launch
Resolving Installation Issues for Autodesk Fusion 360
Resolving network related errors installing Fusion 360
Resolving permissions related issue installing Fusion 360
Unable to set up Fusion 360 for your Autodesk account
Unsupported Operating System warning during the installation of Fusion 360
February 2016
Text in dialog boxes are cut off in Fusion 360
Text or Icons in ribbon, dialogs, or commands are too small in Fusion 360
March 2016
.prt drawing is empty when opened in Fusion 360
Adjusting Windows 10 display scaling settings for Fusion 360
Bodies disappearing with visibility on in Fusion 360
Fusion 360 user interface menus don’t work on a Windows MSI GT72S Computer
How to change the orientation of the origin planes in Fusion 360
How to create a 2D drawing from your CAD file in Fusion 360
How to edit your grid spacing in Fusion 360
Incorrect System time warning when starting an Autodesk 360 application
Issue selecting all features on ‘hole’ command when patterning in Fusion 360
The application “Autodesk Fusion 360” can’t be opened. -10810"
Tutorial will not exit and no option to close on iMac
April 2016
An installation issue is preventing Fusion 360 Drawings from launching
Can’t insert a mesh in Fusion 360
Difficulties Saving or Syncing Designs in Fusion 360
Does Fusion 360 require the internet?
Error failed to open zip package, it is probably locked by another program in Fusion 360
Fusion 360 design has disappeared from the project
Fusion 360 performance degradation after extruding from DXF file
How to configure “Component Color Swatch”
How to dock/undock toolbars and dialog boxes in Fusion 360
How to drive an arc based on the arc length parameter in Fusion 360
How to install Fusion 360 in a Lab environment
How to export multiple bodies as an STL file in Fusion 360
How to receive e-mail notifications about the status of Fusion 360 and future updates
How to switch between a parametric or direct modeling environment in Autodesk Fusion 360?
Performance Tips for running Fusion 360 on high resolution monitor
Sign In dialog repeatedly reappears and is unresponsive to username and password Fusion 360
There is no command on the ribbon in Fusion 360
Visibility status in Fusion 360
When opening a file in Fusion 360, an error occurs saying the file is corrupt
May 2016
Can I use Fusion 360 on multiple computers?
Fusion 360 crashes on startup (Mac)
Fusion 360 is crashing too often, what should I do?
How do I download updates for Fusion 360
How does Fusion 360 get installed?
Install error - nonnumeric port
Is there a difference between the Mac Apple Store version and the version on the Autodesk website?
Recorded Webinars and Hangouts
Using Fusion 360 on a public computer, what is the best way to secure my data?
Selection issues in Fusion 360 on Mac OS
June 2016
Fusion 360 Error Sign in Failure Due to Service outage
How to change the order of toolpath in CAM workspace
July 2016
Fusion 360 Ultimate download is missing in Autodesk Accounts download page
How to re-activate archived projects in Fusion 360
How to export a design in Fusion 360
I have not received confirmation from Design for Autodesk
Request for post processors for Fusion 360 or HSM product
August 2016
Disk full - Fusion 360 Install Error
File Duplicated or Leftover Files - Fusion 360 Install or Update Error
How to access your hub’s Dashboard in Fusion 360
How to create a crash recovery back-up file manually in Fusion 360
How to find the Fusion 360 tutorial files
How to modify proxy server and firewall settings to allow Fusion 360 to run properly.
Imported DXF file in Fusion 360 is not to the correct scale
Internet Connection - Fusion 360 Install Error
Inventor Fusion will not launch in Windows 10
Missing Files - Fusion 360 Install Error
Permissions problem - Fusion 360 Install Error
Problem installing Fusion 360 Error message
Server Problem - Fusion 360 Install Error
Unable to constrain to the midpoint of a line in Fusion 360
September 2016
Fusion 360 is stuck in offline mode
How to configure a proxy server or firewall on Mac OS for Fusion 360
How to install an ADD-IN and Script in Fusion 360?
Installation of Fusion 360 forcing 100% Processor load
Unable to install or run Fusion 360 within Proxy-Auto-Configure environment
October - November 2016
Autodesk Fusion 360 Changes to Benefits - November 2016
Can Fusion 360 create 3D models?
Can Fusion 360 create a model for 3D printing?
Difference between Inventor and Fusion 360
Fusion 360 Drawing cannot launch
Fusion 360 performance is poor after inserting or importing a DXF, DWG, or SVG file
Fusion 360 splash screen when trying to install
How to add Alternate Units to dimension in a drawing
How to check what version of Fusion 360 is installed
How to show only selected component in Fusion 360
Latest Version already installed - Fusion 360 Install Error
Unable to add a constraint to the midpoint of a line
Unable to change the appearance of a mesh body
Update Fusion 360 and try again when opening a design
You would like to edit a Fusion 360 design via an iPad or other mobile device
December 2016
A newly created sketch is deleted upon attempting to rename the sketch in Fusion 360
CAM Expression Variables in Fusion 360
Defining Work Coordinate Systems in the Fusion 360 CAM Workspace
Dialog box Adcefwebbrowser.exe: Path does not exist.
Difference between AutoCAD and Fusion 360
Does Fusion 360 have flow simulation as a simulation study
Download and share buttons are missing on completed renders in Fusion 360
Fusion 360 sign-in failure due to service outage - unexpected authentication warning
Fusion 360 will not save designs to the cloud
How to change Default Mode in Fusion Layout from pan to select
How to change the value in the Resolution option in Capture Image command
How to locate locally cached files in Autodesk Fusion 360
How to save a component as a different design
Licensing not possible after the Trial version is expired for AIMS 2017
The As-Built Joint command is missing in Fusion 360
Unable to generate global contacts for Event Sim in Fusion 360
Unable to select multiple bodies
When launching Fusion 360, an error message pops up saying “The software renderer is being used…”
When saving a design, Fusion 360 hangs perpetually
