Last Update broke Mesh2T-Splines, Mesh2Brep,and Mesh Import Position+Scale
cekuhnen
Mentor Mentor
Message 1 of 24
cekuhnen
While the new mesh tools are quite cool, the update broke the functionality and usability of the T-Splines and Base feature (mesh to BREP) inside Fusion 360 completely.
The problems and observations:
TS and Insert Mesh do not give you a scale import dialog
Only create Mesh object and then insert Mesh gives you the scale import dialog
Quad meshes will be imported as triangles !? Seriously why! makes absolutely no sense!
Quad mesh imported into TS I can be converted back to a quad TS object while the imported mesh had triangles – but then you also have no scale for import.
Mesh imported inside new mesh object with correct scale then fails to be converted to TS because TS then complains about the triangles.
Why does Fusion add a Mesh feature when being inside TS mode infront of the TS feature in timeline?
Importing obj and stl objects in new Mesh objects places objects at random positions.
Adding a new base feature inserting the quad mesh cube also results into a scale and triangulation issue.
mesh and ts video:
https://drive.google.com/file/d/0Byzv_NlyKp_2TDNEM0RKSl9EaDA/view
mesh and base feature video:
https://drive.google.com/file/d/0Byzv_NlyKp_2TzdDSDFnWmxKcGM/view
Currently this renders Fusion 360 for me useless when I have to deal with outside quad mesh data - which is a big part of my process, workflow,and also teaching
since we use various applications dedicated and specialized on the creating of certain 3D data structures using Fusion 360 as the finale bridge that joins
them all together.
Worked flawless before - impossible now 😉
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (23)
Message 2 of 24
mccoym
You can turn off automatic triangulation of quad meshes using a preference. Just uncheck this box:
image2016-7-1 10:6:56.png
Note that Mesh workspace tools only work on tri-meshes, so you will not be able to edit a quad mesh.
I am looking into your other concerns.
Thank you.
Manjiri McCoy
Fusion development
Message 3 of 24
mccoym
The missing position dialog when inserting a mesh in tspline mode is a bug. We will track it internally. Thank you for your feedback - we appreciate your input.
-Manjiri McCoy
Message 4 of 24
cekuhnen
@mccoym Thanks for the triangulation setting tip. this has to be better documented with new releases.
quad meshes come in now fine. the rest scale and position is still a problem.
Claas Kuhnen
Message 5 of 24
mccoym
Yes, the scale issue is being tracked as a bug. As a workaround, you can use the scale tool to resize your mesh and the Move tool to position it. I understand this is just a workaround - we will fix the original issue as soon as possible.
Manjiri
Message 6 of 24
cekuhnen
@mccoym Perfect! But hey this should have been found and solved already before the update - specifically when as a user you cannot not take the uddate!
Claas Kuhnen
Message 7 of 24
mccoym
Could you let me know your OS specifications?
Message 8 of 24
cekuhnen
MacPro 2008
2 x 970 GTX
OSX and Win10 latest version
There is also a problem with the move command
http://forums.autodesk.com/t5/forums/postpage/board-id/124
Claas Kuhnen
Message 9 of 24
promm
Claas,
I am unable to replicate the results that you are experiencing where you inset the mesh, but do not get the insert dialog box.  Can you share your model and may I suggest restarting your machine if you have not done so recently.
Cheers,
Mike Prom
Message 10 of 24
mccoym
I am unable to reproduce your issue on machines immediately available to me - thank you for your patience as we continue to investigate why you are not seeing the Mesh Scale/Position dialog after inserting a mesh.
Could you try to insert a mesh on a direct modeling document, after restarting your machine? And do you see this issue on both your Windows machine and Mac?
Message 11 of 24
cekuhnen
check this:
the dialog pops up a split sec and then goes away and never comes again
restarted pc
installed next update for fusion
restarted pc again
still same issue
https://drive.google.com/file/d/0Byzv_NlyKp_2M2liNlcwRHRWVkE/view
Claas Kuhnen
Message 12 of 24
mccoym
Do you see this on both Windows 10 and mac OSX?
Is it possible for you to speak with me on Monday? What timezone are you in? I can set up a Goto meeting so I can see your screen.
Thanks!
-Manjiri
Message 13 of 24
cekuhnen
Also in OS X after the update same behavior things not working
Claas Kuhnen
Message 14 of 24
mccoym
OK - we have a larger team trying to reproduce this now. Meanwhile, is it possible for you to meet with me on goto meeting? If yes, please email me directly - manjiri.mccoy[at]autodesk.com and I'll set something up for next week.
Manjiri
Message 15 of 24
mccoym
I have one more thing for you to try - your UI appears to be customized. Could you reset your layout, by going to file menu->view>Reset to Default Layout,?
Message 16 of 24
luciacasu
I'm looking into the issue of the mesh body that moves after being scaled: can you provide the dataset?
Lucia Casu
Fusion Development
Lucia Casu
Fusion360 Development
Message 17 of 24
cekuhnen
@luciacasu
How do you reset the UI?
Here are the files.
Claas Kuhnen
Message 18 of 24
LMD001
@cekuhnen
Hello Claas,
Reset to default layout:
Best regards,
Ludo
Message 19 of 24
cekuhnen
@LMD001 Resetting the UI does nothing.
The scale import dialog is mainly missing and only visible when I am in a newly created mesh feature
Mesh objects are imported and then placed in random positions unlike their own xyz=0 world position!
Claas Kuhnen
Message 20 of 24
LMD001
@cekuhnen
Hello Claas,
Yes, the reset to default made no difference, I guess the dev team wanted to rule out some custom settings that could interfere.
Seems like there are quite some issues with the latest update.
The call for some kind of rollback to previous version(s) is very reasonable, and would spare users from these very negative experiences with a basically very promising software.
Unfortunately, some users could even loose confidence in Fusion 360.
Hoping, and confident, that autodesk will resolve these issues very soon.
Best regards,
Ludo
