Lamp icon behavior
Lamp icon behavior
Lamp icon behavior
I think that the lamp icon behavior is wrong.
If i turn off the parent lamp (bodies folder) all childs lamps (bodies) should stay off.
There is no change if we turn on a body when the parent is off, that body stays off.
regards
Phil.E
Actually this is as designed, to give you flexibility. The short answer is it is a two stage visibility switch. One bulb for each body and one bulb to rule them all.
Think of it this way:
What if you have a mix of bodies in that folder. Some are bodies that you wish to see all the time, and some are bodies that you wish to not see all the time, but you don't want to delete them. The individual bulbs do this.
Imagine that you wish to also shut visibility for ALL bodies now and then. The folder bulb does this.
It sounds like you would prefer to leave the bulb ON for the folder, and just use the individual bulbs for each body. Does this achieve your workflow?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
jeff_strater
Excellent question, thanks for posting it.
Actually, this is by design.  We use a "valve model" of visibility (think water valves) of visibility.  For something to be "on" (visible), all the bulbs from the root to it must be on (for water to come out the faucet, all the valves between it and the city water supply must be open).
The main reason why we wanted to use this model was a scenario such as this:  Say a component has 5 bodies in it.  You are not really using 2 of those bodies, so you have made those invisible.  But, then, you decide that, temporarily, you don't want to see the entire component.  So, you turn off its lightbulb.  Then, later, you are ready to see the whole component again, so you turn on the component's light bulb.  Do you expect all 5 bodies to be visible, or just the 3 that are in use?  Our belief is that you want only the 3 that were visible before.  So, we retain the bodies' visibility.
You could argue that while the component is invisible we should not show the bodies as visible, and we did consider that.  However, we decided that it was better to show the bodies' state so that you know what will be visible when you turn the parent on.
Hope this helps make this a bit clearer
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Ok, a little bit confusing for me, a screen cast can help me to understand.
I expect that if I turn off the folder all the bodies inside of it have to stay off because the hierarchy.
I don't know if in Fusion360 exists a hierarchy.
If the body can't override the parent (folder) visibility switch (state) I think that it is forced to stay off.
If the first top folder is off all the assembly will stay off, bulbs too.
regards
jeff_strater
sorry for the delay.  Here is a short screencast showing one workflow in which this might be useful:  http://autode.sk/1BQY0ta
Hope it helps make the reasoning a bit clearer.
Jeff
Jeff Strater
