Excellent question, thanks for posting it.
Actually, this is by design. We use a "valve model" of visibility (think water valves) of visibility. For something to be "on" (visible), all the bulbs from the root to it must be on (for water to come out the faucet, all the valves between it and the city water supply must be open).
The main reason why we wanted to use this model was a scenario such as this: Say a component has 5 bodies in it. You are not really using 2 of those bodies, so you have made those invisible. But, then, you decide that, temporarily, you don't want to see the entire component. So, you turn off its lightbulb. Then, later, you are ready to see the whole component again, so you turn on the component's light bulb. Do you expect all 5 bodies to be visible, or just the 3 that are in use? Our belief is that you want only the 3 that were visible before. So, we retain the bodies' visibility.
You could argue that while the component is invisible we should not show the bodies as visible, and we did consider that. However, we decided that it was better to show the bodies' state so that you know what will be visible when you turn the parent on.
Hope this helps make this a bit clearer
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
