Taper issue
Taper issue
Taper issue
I don't know if it's an issue.
In Model mode If I create a box I should be able to add a tapering after the extrusion.
This valid for the cylinder also, I should be able to create a cone.
Is it a missing feature?
regards
Phil.E
This is as-designed. Primitive box and cylinder do not offer taper. I'm not sure why other than simplicity.
You also cannot edit the sketch for Primitive. There are limitations.
Could you post this on the Idea Station, perhaps other users would like to taper their primitive Box and Cylinders.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
