Does anyone know what the knot vector is for control point splines? I can't control it when building the spline, but I know it's necessary to generate the curve. For reference I'm in 5th degree, using 6 control points, and no external constraints. I'm aware there are knot vectors related to the NURBS surface, this is not that, it's just the basic sketch spline.
Solved by MichaelT_123. Go to Solution.
Hi Mr JolparJulian,
Consider familiarise yourself with digest of the subject in F360 API docs.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-de6fb48b-371f-49b6-80be-0ef62745404e
More detailed knot-theology can be found in academic publications.
The subject is really interesting ... and not trivial ... in many aspects.
Regards
MichaelT
