Keyboard shortcuts dropping out
William_Dec_45
William_Dec_45
I removed most of the icons in the toolbar to sort of force me to use the keyboard shortcuts. I think the rest of them are working, but the "G" for the line tool no longer works. It did, but now it doesn't. Is this just a dirty keyboard, or is there a problem in Fusion World with the G key? Thanks
jhackney1972
Fusion, out of the box, uses the "L" key as a shortcut key to start the Line tool.  If you really want to change it, take a look at the Animated GIF below.  It is not recommended.
John Hackney, Retired
William_Dec_45
Thanks John. I had forgotten about that technique for changing shortcuts. I remember distinctly using the "L" for line. When I recently started using the keyboard more, I noticed it had changed to "G". I wondered why, but then it occurred to me that those who keep their left hand on the keyboard and their right hand on the mouse, can reach the "G", but not the "L". I thought that was a pretty good idea. That still doesn't explain why it quit working over the past few days. I'll see if I can fix it using the technique in your GIF.
