key pipe at notch workflow
nickoATKINS93
nickoATKINS93
I am drawing a tube chassis and would like to key the tubes together to make assembly easier. I have managed to do this by creating a sketch on the tube centerline and making the key then extrude it as a new body past the notch, then to get the corresponding hole I split the inside and outside face of the tube with the key. this is quite time consuming and was wondering if anyone had a better method?
thanks
davebYYPCU
See if this helps.
For mass production, I would streamline even further.
Might help....
nickoATKINS93
thanks for your solution very helpful
